1sik32valve
For the ones that have them are you running it through the radiator still? Inlet through radiator done through external cooler then back? Or just straight through the external one?
i used to run it through the radiator as well, but now i just run it standalone as the radiator cooler started leaking.
"over-cooling" is possible, so don't run a giant cooler stand alone without a thermostat.
yep. that one is about the size that i have.
run that in line with the factory cooler and it should be fine.
