Headlight adjustment for gen 2
1sik32valve
San Bernardino
Is there an adjustment so I can raise my headlights? They point down really low. I have to drive with my high beams on to see ahead of me. Thanks it's a 97 LSC
i'm sure there is, but i don't know how. the gen 1 has adjuster studs that you turn. it will raise/lower and shift the beam left/right with those studs.
Yeah I know gen 1 is like the tbirds have 3 studs. Darn ok thanks ill just have to just bust into it and see.
It has two IIRC 4.5 mm or 4 mm hex type bolts. Not like the stud type in the gen 1, which you also turn a hex type bolt but in Gen II they are faced upwards and much better/easier adjustment. In gen 1 it moves the actual light while in gen II it adjusts the inner housing.
Here's a pic of the vertical adjuster. The horizontal adjuster is nearer the fender.
Awesome thanks guys appreciate it I can't see and I don't want a ticket for use of highbeams when not needed.
You should check your car for front end prior accident damage. That's really odd that both of your headlamps are pointing so low. Take some pictures & post them for us to see. Maybe we can shine some light on your situation.
It does have the coil conversion on it not sure what company but the front end does sit lower than the rear. And also to adjust up is it counter clockwise or clockwise thanks.
I just wanted to see if there was, if so I wanted to bring them down a bit level with the headlights and run HID in the highbeams too, or point them down and use them as fog lights lol idk just wondering.
