Painting the carpet
der3wuste3fuchs
N/A
So I hated how nasty my carpet was from (more than likely) the last slob of an owner. The car is a great car with a ton of potential and a great deal but it needs the junk (food) dug out of the crevices.
I chose to go up to my local OReilly's to purchase the paint since everything on amazon will not ship to Hawaii. I ended up getting their Duplicolor flat-black carpet/vynl paint. There were better out there, I just decided one day to do this
http://www.amazon.com/Dupli-Color-HVP106-Black-Performance-Fabric/dp/B00098PO3G/ref=sr_1_1?ie=UTF8&qid=1363741234&sr=8-1&keywords=duplicolor+flat+black
I'd recommend about 4 cans of this stuff. I didn't paint the side panel carpet or the carpet on top of the rear seats but I did my job with three.
As for supplies there isn't anything too fancy you need, but here are some of the things I had on hand:
1.) Bucket with warm water and detergent
- any thing like dawn dish soap will do, the company sells a "prep" solution but you do not need it as it's just a normal degreaser
2.) scrub brush
- I used a bath scrub brush with nylon threads that worked well.
3.) Tape to seal off the edges
- I used good ol' masking tape which worked well. Ideally, you can remove most of the center console and other trim components but I didn't feel like taking them out at the time. I also used plastic wrap to help wrap and protect things from loose particles.
4.) Handheld vaccum
- I used this since after taking out the seats I couldn't drive up to the vacuum station, and they would have a fit if I tried to do the whole process at the station ha. It's also handy if it has an extension to get into crevices.
5.) Blow dryer
- I used this to speed up the drying process after cleaning in conjunction with the vaccum.
6.) Needle or similar small object
- you will need this to disconnect the rear seat belt.
7.) (1) Ratchet with 5/8" socket and 6" extension
- depending on how difficult it is for you, you might also need a u-joint.
8.) Small utility/pocket knife
9.) A good playlist
I started by taking the front seats out. First slide the seats all the way forward and taking your ratchet, undo the two rear bolts exposed on the rail.
After the rear bolts are removed, slide the seat all the way back in order to see get to the two front bolts. This is where I used the extension and a u-joint since they are under the seat a little bit. I felt like an idiot at first for not finding them however they are underneath the carpet. my carpet was so nasty you couldn't tell the slit was there to pull up the carpet, but once you dig around and pull it up they should come right out.
After that you can lean the seat forward to ease taking them out but I had them straight up without a problem.
At this point I shut the car off and removed the (+) terminal cable from the battery. I waited a few minutes and then presumed to disconect the cables from the seats. I then started to disconnect the cables from the seats.
tilt the seat up from the back and remove the grey cable. Use something small and flat to press on the bottom latch and lift out. This was quite complicated as I screwed my arm up in a motorcycle dance recently but still possible. Helps if you have a second person. Then you can disconnect the yellow cable. This guy is a jerk. I used a very small knife to press against the side latch. You'll have to dig it in between the latch and the housing and push left or right.
I didn't bother with the SRS power down procedure, and everything turned out fine. I guess I'll find out if I'm in a crash though.
Lift the seats out. The seat belts will still be attached but it doesn't matter as you have enough slack.
Once you get the front seats out you should find all kinds of nice goodies and
oddities. Mostly you'll see stains of spills from the right side of the driver seat or opposite in the passengers. I had enough for a happy meal.
After that you can take out the rear seat. It's fairly easy, just use a small needle or anything of the like to stick in the pinhole and unlatch the seatbelt. Once you take that out, push the two latches (under the lip of the seats, located left and right) inboard and the seats should come up. You'll have to wiggle the seat belt clasps through the seat whole.
You might find another happy meal.
After that you can start vaccuming/collecting/eating everything you can off of the floor. Once you get all the girl hair and cookie crumbs out, you can start washing.
I wrapped the seat harness plugs with plastic wrap and taped the outside so I wouldn't directly put tape on them.
Use your detergent and hot/warm water and give it a good scrub down. Don't miss anything. I concentrated on my nice mustard stain from, what I'd like to think, a backseat hot-dog lover.
[img=http://s23.postimage.org/3o3n5nex3/asdfasd.jpg]
Once you let the floor dry (you can vaccum again thoroughly and use a blowdryer), start taping up all the trim. More than likely your console pieces and a few others are very loose so it's easy to get a good covering. I used a bit of plastic wrap on other things, however the spray is not very loose at all and the particles don't seem to scatter and stick.
After you have everything covered, spray away to your heart's contempt. when I first did a spray, I sprayed a little too close and spots were noticeably stiffer and darker. Avoid this and stay about 6-8 inches away even if it looks like not much is going on. All spraying rules apply; use even strokes, etc.
I painted over the foot pedals and foot rest and it seemed to look quite good. When you use any of these spray paint dyes, the fabric clumps up slightly, however don't be scared as after the carpet dries you can take your hand and give a good co-ed rub down with your hands and the carpet will smooth out. The paint dries fairly quickly so you can get one side coated, give a good rub down and another coat to move around the fabric.
After your all done it should look quite good. 3 cans should do the job with another for touch-up. (I did not paint the rear seat carpet and the door panel carpet as mentioned earlier).
I actually only had 2 cans of paint thinking I could get away with it. Ended up having to wake some friends and have them drive down and get some more, so I micro-managed and left under the seat out until I could get my hands on a third can.
After it's all said and done, just reassemble everything and enjoy your new carpet. The paint has held up pretty well, however where my feet move around I've noticed it's a little bit lighter. I think if you touch it up and get all the moved fibers it'll keep up. I'll be painting the interior pieces sometime anyway so I'll probably give it another light coat then.
I just decided to write this up as my experience, less than a how-to. however I started talking in the first person so there you go I guess. A ghetto way to do things but it is drastically better in my case and I don't have to shell out the cash for a new carpet, so pretty happy. And, the overseas fish market small is gone of course.
Ian
Cool right up! Ive ben scared to do this but i might now! haha:D
wered you get the paint?
Not bad at all, like you said, cost effective!
+1
Floor Mats Boss. Then, you won't have to worry about wear marks under your feet.
2006 Lincoln LS in Cashmere Tri-Coat Metallic.
How is the texture of the carpet now? Is it still soft, or is it rough now?
I tried this product and it frankly sucked azz. Made the carpet rough to the touch, and in really cold weather it would get so hard that the paint would actually start flaking off...just my experience.
Thats why I went with carpet dye instead of paint:
http://www.lincolnvscadillac.com/showthread.php?t=83956
I do regret not going for the black dye instead.
It's not paint.. It's a dye, and is meant for hard surfaces, not really carpet, or it will be nasty and stiff like it has hair spray in it..
I used the exact same product to dye my console.
This is how it turned out on the console
Shift boot by BLWNBYU, on Flickr
The texture of the carpet is still ok, however as I said before the rough spots where I painted close are a little stiffer. Not on the same par as spraying directly with krylon or anything like that, but noticeable.
Luckily, here in Hawaii I don't have to worry about cold temperatures and it will hopefully not flake in the future. I did get cheapo floor mats for the feet area where I sprayed it on too thick and everything still looks great. Carpet dye is much better and won't stiffen at all however it is extremely messy.
With any of these types of "dyes in a can" you have got to clean your carpets thoroughly and really be stingy about the amount and closeness of the nozzle.
The light makes the color not look as good as it is, but there is only slight discoloration.
Thanks for the tips.
It is a dye, I just use spray paint as a generic term. It is sort of splotchy when it comes out and isn't especially made for carpets, however if you play with it you can really work some magic.
As I said before though, my carpet went from a 2/10 to a 9/10 for 20 bucks so I can't really complain. You're trim pieces look good, I can't wait to do my center console. I'll probably use something a little more glossy though.
For anyone else, if you want to use the good stuff, get the VHT brand. they work much better and are specifically (as stated) for carpet.
http://www.amazon.com/VHT-SP942-Vinyl-Black-Satin/dp/B000CPIN9S/ref=sr_1_3?s=automotive&ie=UTF8&qid=1363807456&sr=1-3&keywords=carpet+dye
You really have to play with these things to get it right. I did not wash my carpet, dry it thoroughly, and sprayed it too thick so mine won't be perfect.
Another product you can try is the SEM version. Their company is very renowned for high-quality paint and color matching. When I paint my seats, I will be using their leather paint.
http://www.amazon.com/SEM-Paints-SE...TF8&qid=1363807610&sr=1-5&keywords=carpet+dye
Yeah, I was planning on it. I just went to get some cheapo $13.00 mats from the local auto store when I got my bulbs. Until I find someone who does nice custom LS mats, or find some that fit I'll be upgrading.
Ian
Ian
IMO SEM has the best quality dyes hands down.. I had SEM for mine, but it wasn't a good match, which really pissed me off because I had more than $50 worth of it.. :mad:
It was supposed to be mixed for my interior code and everything, but that problem seemed to be only related to my particular interior code..
The SEM definitely sprayed more evenly and seemed to stick better. It's actually underneath the stuff on there now..
That really sucks. They are usually awesome about color matching. Although, the LS interior between it's color and it's fading is near impossible to duplicate and match every trim piece.
If you really wanted to do something accurate I guess you can get have them send you the colors and you can mix it yousrself and use a compressor to spray it on. But at that point I guess you could just buy new trim pieces.
SEM sprays amazingly, I think if I actually shampoo and clean the carpets I'll give them a shot again. I can't wait to do the seats with their leather paint.
By the way, that's not a Cobra you're sporting there is it?
You only paint the carpet so it matches the drapes...
This guy has black carpet. I'd lay good money that if he'd just pull it out and drape it over a picnic table, dose it with Tide in hot water with a stiff scrub brush that it would turn out looking and smelling better than what he did.
I have never seen or had outstanding long term results with vinyl paints on soft items. Plastic consoles are ok, but I'd much rather have an OEM black console with the correct texture and shade of color.
The carpet is ridiculously bad, some spots there is no carpet. The grey color shows all of these bad spots and more. Cleaning would not have fixed much, the black hides it a lot better. Not to mention that the dumb color scheme lincoln used for the interior of a BLACK car, with boring GREY interior.
Either way I will be painting the seats, trim, and other pieces black to match. I would rather have an OEM black console too, however I'd have a better chance finding some good blow on eBay then finding it. Also, I bought this car for a steal at $3500 and I like to restore it with my hand by recycling what I have.
Ian
