MMAFIGHTER121
So, cruising along about 40-45 I notice that it hasn't shifted into 5th because I'm cruising at about 2500RPMs. I put into into SST to try to force the shift, and it all of a sudden drops into 3rd and TRANSMISSION ERROR and "E" gear. I turn the car off for a little while, then restart it and everything seems normal. Once again around 40MPH it hasn't shifted into 5th, so I floor it up to around 60 then it really HARD slams into 5th. For the remainder of the trip, it shifts normally. Next time I get into the car, It starts off shifting normally, then after the car has gotten up to temperature, I have the same problems again. (won't shift, floor it - slams into gear, works normally). Now after it shifts normally after the "floor it fix" for about 5 or 6 stops, it starts refusing to shift again, then I have to floor it.. and that's getting really annoying. What does it look like is going on here?
