sputtering and check ingine light flashing
gende82
Bolingbrook
If anyone has a suggestion, when i get on the gas pretty hard the car sputters and the check engine light flashes. i did recently have an egr problem but that has since been fixed
This is getting to be an every other day thing.... It's your coils. Replace all of them along with your plugs. Stop driving it hard, a blinking light means a bad misfire that will destroy your catalytic converters.
i have tons of suggestions, most of which would be proper to say in front of people here...
so how about this for a suggestion, how about you try a little searching?
more than likely, your just in need of a new Johnson rod, well that and maybe half a set of coils.
Ditto!!!!!
Well... the stickies suck...
Maybe a better laid out, common problems with the LS thread would help things..
