sprocket
If you read last post in the diamond anniversary thread, you can see that I am concerned that the new spark plugs are not going in all the way.  Here's a recap.
1) Bought Motorcraft plugs and wires.
2) Removed the cheap new plug wire set that the previous owner had installed. This required destroying five of the eight plug wires to get the boot off the plugs.
3) Removed the old spark plugs and replaced them with Motorcraft.
Here's where the problem lies. This engine was overheated by the previous owner and I got the car cheap because of that. When I first got it, it had a cylinder six misfire. I replaced the plug wire and plug and the misfire stopped. Because I had to destroy the plug wire to remove it, I decided to replace them all.
Now here's the part where my friends think I am crazy:
I don't think the plugs are threading in all the way, and I had trouble getting them started. One of my friends had the touch and was getting them started pretty easily. I've never had this problem before. I'm expecting the plugs to thread in all the way to the tapered shoulder, but I'm only counting about five full turns before they get tight. In the case of #6, I don't even think it is going in that far. I am able to turn them by hand almost all the way to tight and they do feel like they are coming to a dead stop. I don't get the feeling that I could make them go further. I tried taking out a plug and putting the original one back in and it goes in the same amount.
So now there is misfiring and due to bad weather I can't get back to the car today with a code reader and a spare set of coils.
Am I imagining things? Or are the plugs not supposed to go in as far as I think they should? I had no trouble getting the old ones out, and they didn't seem to require very many turns to remove either.
The auto parts store had a spark plug thread repair kit that just chases the threads but doesn't cut them. It's $57 though, which is a lot to spend if I am just imagining things. *CORRECTION* I don't need that full kit. I might just need a chaser which is about $7
