stumped
cvardell
columbia
so my 93 wasnt starting when i turned the key, replaced selenoid and everything was cool for like a month.... then it stopped working again got another selenoid and it started fine that day, but now only 2 days later no start once again. FML i know please someone point me in a general direction here.
lol duh how about i throw in that it wont even turn over just like i turn the key and nada
Possibly your neutral safety switch is out of whack? Does it do anything if you wiggle the shifter while you try to start it in park?
nothing when im shifting it ima try and locate a starter and replace will post back soon to tell
Have you checked your battery cables? An intermittent connection will do as you are describing.
they seem to be fine everything works electrically just doesn't wanna do anything lol i have no idea how i am gunna get that started off so cramped in there. :(
When I had a bad cable everything worked electrically as well. Just a possibility, I am not saying that is what is actually wrong.
battery?
When I first got my 95 the dealer told me $500 for a tune up. Drove to my parts store 1 mile, bought some plugs and wires, went to leave and dead. Parts store guessed battery, tested NG. Put in a new battery and all was well. I had 10 years later a crack in the battery positive clamp. I found this after the 3rd altenator. My guess would be the battery or post clamps. Can't rule out the starter. lol TONYyyy:D
I'll do your tune ups for $150 (plugs + wires)
battery plugs and wires all replaced this last summer. so today i went back into town and it started up fine drove it back to my house and then turned it off and then it started again. then no start. i turn key and it sounds like starter just cant turn so ima check it out this weekend hopefully it wont be 20 degrees out.
Yes I would go with battery, cables and connectors, and most definitely starter. Just do a refab on ur electric setup. And check fuses. For the hell of it
