Fixed
I caved in and took my LS to a local auto-shop. Turned out not to be my fuel pump, however the filters where black they needed to be changed eventually after 95k miles. The starting & stalling problem was due to a dirty R&R idle valve, It was gunked up, They had to clean and replace the IACV gasket. This piece extends from the engine under the cover on the right side. Looks like a black hose. They also did a relearn procedure,the IACV gasket part about 6-9$, the relearn procedure 90$. Total cost $150 parts and labor. Thanks to the previous posts! The LS is back on the road.
and Dwizzle86 I got my fuel pump from partsgeek for 88$ and it was identical to the stock one, The process is tricky all together. Hope you can fit it in there! Good Luck.
