Guys i need big help here PLEASE
ok so update, i tested the coil packs and found it to be a shocking experience lol. so i have spark. i also found out that my radiator has a hole in it so i guess now i know where all my coolant is going. that means in theory besides my radiator having a hole in it everything else should b working fine but i still cant get it to start :(
gonna pull out the radiator tomorrow fix it and see where i stand
Unplug the electrical connector to the MAF and see if it will start then.
Your oil is fine? Do you mean just the oil level is okay? Or you verified the integrity of the oil is okay as well.
You say you're new to cars. So I just want to make sure that you verified your oil is not milky, doesn't smell like coolant or just plain looks like what oil is supposed to look like.
Based on your symptons what immediately came to mind is what Joe said....a blown head/gasket. If that is the case you are wasting your time pursuing anything else.
also disconnect the battery while you fix/ change the radiator. you should get a new one you can get one cheap from rockauto.com that way you can reset the pcm and then try again. since the radiator had a hole you probably drain almost all of your coolant out and caused a fails safe mode. if you don't have the message center on your dash then you wont know if you went into safe mode unless you know what it is
my oil looks fine i mean it looks like what oil is supposed to look like. no milk or anything, and how do i test for a blown head gasket
Well checking the oil was the test...If you get antifreeze into your oil pan it ruins your motor.
oh i c, ok well the radiators fixed i have full coolant and oil wit no leaks. getting my battery charged as we speak so tomorrow im gonna try staring it again. wish me luck guys
