Has anyone ever used ebay rotors?
micahs97m8
Browns Mills
I haven't had any real bites on the Mark, and I sold my pitiful little honda, so I am rebuilding the Mark VIII.
For starters I will be swapping out the slipping trans with a race built one. Then I will be replacing the blown brake line with brand new stainless braided line from Paragon Performance.
While the brake system is being worked on, I may as well do Rotors and ceramic pads. I found these: http://www.ebay.com/itm/Front-Rear-...VIII|Submodel:LSC&hash=item3f1b321caa&vxp=mtr on ebay, but i'm never sure about ebay parts. Any suggestions?
How did i figure they would be drilled and slotted? LOL
The cheap parts store stuff works for me. I always buy cheap rotors and decent pads. Has worked very well.
Read my mind.
I bought expensive rotors back when I had my Marquis and they warped over and over again. Bought cheapies from Pepboys and never had a problem. Since then I buy the least expensive rotors and ceramics pads, rears get the same but I use semi's as thats what usually in stock.
There was a company on eBay called R1 who once was on LVC offering discounts to members. I bought 2 sets from them and was very pleased. I'd put money they get their parts from the same places.
R1 Concepts
I've bought 2 sets of rotors from them on eBay. They sell good quality stuff and seem to be a really good company.
I bought one set in Mark VIII bolt pattern, and then when I hubswapped/Cobra brake swapped, I bought from them again. I've had no problems with them whatsoever...
Just my 2 cents.
Cheap rotors good pads that is the model I have always used. B grade steel high recycle content makes them cheap.
Add yet another recommendation for R1 Concepts. When I first got my Mark VIII, I was was warping rotors left and right (I blame it on HIGHLY spirited driving and continuous corner carving heating up the brakes). After warping my second set of OEM-style rotors, I bought a set of drilled and slotted rotors and ceramic pads from R1 Concepts, and never had any more issues with warped rotors or brake fade from heat in the 3 or so years I drove the car (HARD) after that.
I've got r1 rotors on my car also..they are ok rotors, no complaints.. they are 13" cobra fronts 11" cobra rears
is that so?
i've never seen anyone else say that before.
what i have seen is that many motorsports run blank discs.
