dnsherrill
unfortunately it's locked...I wonder how much I'll pay to have it unlocked
a search produced nothingI think their is a guy on the SVT forum that can unlock.them too. Frenchi is his user name I believe.
thanks, do you know how to tell the difference between 1st and 2nd? or what the software is called?
Unless you have an AF gauge how would you know it is running rich?
I don't know.
.....it 'seems like the mileage is less since I installed it. But it's only been about 40 miles so far, and intown driving. i won't know for sure until a few tanks go through it and I drive modestly
yep, Data Logging is one of the functions I plan to explore..right now I'm super stoked at how it shifts and stays in (3rd?) a lot longer...no regrets on the the $260 I have invested
my OD works, stays in 3rd till around 60-70 mph....I'm still figuring out how to drive this 'new' transmission...before it would always shift down around 40 moh, to about 12-1500 rpm's....mushy pedalIt should stay in 3rd till you let it have 4th. Does your OD button not work? I had that problem with mine. Mine shifts at 6000 at WOT.
what I meant was, my OD works, but for now I don't use it except on the highway, cruising over 60mph..trying to stay over 1500 rpm's to minimize the drone..
okay, so I don't know what 'WOT' is..wide open throttle?
when I installed my tune there were multiple option parameters regarding WOT and different parameters. I didn't know what those are so did not select any
