Hot*Mk8
Hi, guys,
I dove into the joy of trying to coax out the valve covers today and then had to peter out because my brain became kinda scrambled.
On the driver's side, the book recommends removing the wiper motor assembly, which I didn't do. It also recommends removing the fuel injector connections and wiring harness which I partially did. The two connectors and post push-on type are right underneath the fuel lines and a real nuisance to get to. So I loosened the front two. Brake master cylinder is loose, power steering fluid reservoir and bracket and all the sensors above and next to the cover. I'm really close, but the remaining fuel injector connectors seem to be screwing me.
With the passenger side, it was super easy to get to, but the heater hose seems to be preventing me from lifting it up enough to extract.
Any little bits of manly wisdom would be SO greatly appreciated. The reason for the gasket change is that I did a tune up on this car (the 98) last week and discovered copious amounts of oil in the center plugs and coils. I have new Motorcraft coils on the way along with replacement gaskets, of course.
Thanks!!!!!!
Thanks!!!!!!
