Has anyone ever come up with a method to repair broken mounting tabs on the inside of a gen II door panel ? I have one with three broken tabs that some idiot must have tried to pry off instead of lift off. Thanx Bruce
I had exactly the same problem and found that if I used padded, two-sided sticky tape along the vertical edge where the piece wraps around on the window side it worked really well. It is seriously irritating, though, I know. I had to go into my doors three times and these were already broken when I got there and one of the main tabs on the trim ring around the door handle.![]()
Use a piece of aluminum foil and make a bottom/side mold of the hooks on the passenger door. Tape this to where you need the hook on the other panel and pour some fiberglass resin in the mold. You can add glass for regitity with small pieces and just tap them into the mold with a popsicle stick. You can buy all you'd need and have PLENTY to spare for about $30
Omg I hate this phone
No, just find another door panel is the only way I know. You know Ford still sells door panels, but they are expensive.
There are some brand new oem panels on ebay for about $150
Yes I do. How complete do you need them, armrests, switches etc ?
