Anyone use paintscratch.com
Luk3
New Bedford, MA
Has anyone used paintscratch.com products to colormatch thier
chrome trim? I was thinking of trying this instead of paying a shop to do it.
I read that Dupli-Color is crap and won't last, was wondering if this stuff is any
better.
yes a used them in my surround painting (search for write up) they are a good company... You'll want the use a self etching primer as i didn't and have a spot that peeled.. you'll also want to test a spot first as my color was a little darker than the rest... Paintsratch says they will replace any can thats off...
Just curious, what color are you looking for?
I got a few cans of the silver frost unopened that I no longer will be using since I will be selling the car
But yeah paintscratch is a good match. Grell has a nice write up on it
Yeah, I used them when I color-matched my Sirius antenna. The color (Vivid Red Metallic) was spot-on, and the kit I got from them included pretty much everything I needed. Based on my experience, I wouldn't hesitate to recommend them.
you sure thats you color dunn... your pic looks BQ paint code!
Rell, I have no clue what the "actual color" is called. I just know it's silver, lol. I googled "Frost Silver Lincoln LS" and the pictures that come up appear to be the same color as mine.. I want to paint over my chrome accents on the front and rear bumper. Probably the grille as well.
your paint code is on the sticker on the inside driver door sill... it will be a two letter paint code
here's most of the First Gens
Midnight Grey Metallic -TV
Silver Frost Metallic - TS
Vivid Red Metallic - G2
Silver Birch Metallic - JP
Ivory Parchment Metallic - HC
Ceramic White Pearlescent - F6
Aspen Green Metallic - P5
Light Tundra Metallic - DV
Charcoal Grey Metallic - TC
Autumn Red Metallic - GT
True Blue Metallic - L2
Medium Steel Blue Metallic - SP
Black Clearcoat - UA
Light Parchment Gold Clearcoat - BQ
Medium Cypress Green Clearcoat - F3
Medium Charcoal Green Clearcoat - FT
Aqua Blue Metallic - L3
White Pearlescent Metallic - WF
Dark Green Satin-FU
Estate Green-ST
Graphite Blue-KX
Deep WW Blue-LL
Dark Green Satin-FU
Estate Green-ST
Graphite Blue-KX
Deep WW Blue-LL
Thanks! I'll check it after work
This confuses me. The Ivory Parchment Metallic and the Ivory Parchment Pearl use the same code...HC
These are from Paintscratch... other list was from another member
Light Parchment Gold Metallic BQ/M6904
Medium Cypress Green Pri Metallic F3/M7022
Autumn Red Metallic GT/M6934
Ivory Parchment Pearl Tri-Coat HC/M6944
Silver Birch Pearl Metallic JP/M7052
True Blue Pri Metallic L2/M7023/M7029
Pacific Blue Pri Metallic L3/M7024
Aspen Green Pearl Metallic P5/M7056
Charcoal Gray Pearl Metallic TC/M7050
Silver Frost Metallic TS/M6720
Midnight Gray Metallic TV/M6852
Black Ebony UA/M6373/M6877
Ceramic White W5/M7018
White Pearl Tri-coat WF/M6864
Performance White WT/M6640
Dark Denim (Interior) M4261K
Medium Graphite (Interior) M4245J
Medium Parchment (Interior) FA812OI
Hey Rell, how much paint did you buy from them?
IIRC I purchased 2 12oz cans of base coat but remember wishing i had another can... I also patched my front plate holes too... Just depends on the color i'd imagine. I'd say order way more than you need...
