lincoln_zero
In August, Finished eating dinner at Kelsey's with friends. Did a nice show, just to end the night.
2002 Lincoln LS V8 Burnout VS - YouTube
No thanks it M4rk, he just didn't stated when he made the clip,
I at first though he also just finished dinner tonight and uploaded his vid.
Lincoln_zer0, on the youTube page, directly below the vids, is a "sahre" button,
click it and change it to long link URL and it copies to clip board, then just past it
in the message dialog box and it will do the rest it self.
Just weld the differential gears together BigRig![]()
There was a gen ii with LSD. 02v8sport i believe.
He sold the LSD for like $1k before selling the car.
290-300hp? Thats a little opimistic dont you think?
Pretty sure someone already tried it, it didn't work out that well.. can't think of the name. It was a white gen II v8.
Hey zero, you should put that car on a dyno - I would love to see some real hp figures.
You can smoke both wheels in an open diff when power braking. When you floor it with an open diff, the wheel with the least amount of traction spins. One wheel isn't spinning, so the ring gear is spinning the other one. When you apply the brakes and apply power, both rear wheels now have equal traction as far as the diff is concerned, so the ring gear will spin both axles. This is something to keep in mind if you get stuck in the snow, apply the parking brake then ease into the gas. A stuck open diff car will then start applying power to both wheels. The only thing is, with the 2nd gen LS having an electric brake that you can't control how much brake is applied I don't know how it would work. Now this doesn't mean brakes plus an open diff is as good as limited slip, limited slip is still far superior. It does give the open diff guys a little extra traction that might make the difference between moving and spinning.
Lincoln zero I thought you had a genII? Didn't you trade that one in?
Ok, so it is possible to get both spinning, I just need more practice.
Operator Error ?
Stops, you might have to teach me.
Ah yes, Limited Slip Diff. ok thanks got it, same page again.
Can others smoke both rears while doing burnouts like this ?
