Billet front wheel adapters machining.
Right on the Mark
here
Ok I'm going to have to make a disclaimer here because this is my car and I work on it how I please. This write up does not imply that this is the only way to do this or the best way.Just way I did it. That said,on we go.
Thought some might like to see these being made. Like I mentioned in other threads I could not find anyone selling 4.250bc to 4.500bc adapters that also had to have the 4.5bc tapped 1/2-20 for the long wheel studs for the welds
Here is the large chunk where it all starts.
Turn down OD look at all those chips.
Here are the 2 blanks
All the holes done.
Wheel studs in
I also had to change the angle of stock lugs to hold the adapters on to match 90 degree countersinks in adapters. Here is fixture and machining new angle.
Was some work but cost 0 and got what I needed to mount skinny welds up front.
So with the added thickness of the front wheel adapters you made, how much do the wheels stick out if at all? I thought I remember driller's car havig an issue with the front prostars sticking way out because of the need for a spacer to clear the calipers..put up some pics of the car when you get all the wheels and tires mounted! Love the look of a nice street/strip car!
Yep they stick out some. But for the couple times down the track should not be a problem. I will take front shots soon so you can see how much.
Here you can see how they stick out. My spacers are alittle thicker then 1 inch like some. I made mine the same thickness as the length of the stock front wheel studs so I could put them right on.
Here are some shots of the alum front lugnuts I made to save some weight.
Cut off and roughing in.
Finish small OD and drilled.
All done.
Also made liteweight washers for these
On rims
Rears ohhh ahhh
What kind of Lathe is that and Aluminum Lug Nuts aren't my type of thing I gotta say.[/QUOTE
I've only ever seen 1 aluminium lug strip or be damaged and that was an installation error.. user error really. They are usually T6 temper 7075 Aluminum but he should have no problems as he doesn't have that set up for a daily driver.
Not to argue but I will at this point. Who have you seen using aluminum lug nuts? I mean he can make them and use them on his car and for Drag Racing I don't see a problem with it but not sure if it would pass Tech if they new they are aluminum?
That is trying to save such a small amount of weight to me in a place that I do not wish to worry about possibly seizing on or galling. I mean all you have to do is round the hex trying to loosen it and then your gonna really be screwed so to speak :rolleyes:
Might be heavier but I made my Lug Nuts out of 316 Stainless but that was for my Chevelle.
Those are really nice, I hate trying to polish lug nuts on wheels like the rally or rally IIs on my GTO. End up taking them all off.
Tuner guys love the aluminium lug nuts, 31g each is nothing; I thing most people run them because they can get color matching but I could be wrong.
You can get them for just about anything and in any color you want, or just have them anodized.
Kluhsman Racing Components 8202 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 12mm x 1.25, Open End, Black, Aluminum, Set of 16 Ship Date: Tomorrow
Price: $51.95
Gorilla Automotive 44037BK - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Black Anodized, Set of 4 Ship Date: 10/15/2012
Price: $25.99
Kluhsman Racing Components 8209 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 1/2 in. x 20 RH, Open End, Black, Aluminum, Set of 20 Ship Date: 10/8/2012
Price: $51.95
Gorilla Automotive 44137BK - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Black Anodized, Set of 4 Ship Date: Tomorrow
Price: $25.99
Gorilla Automotive 44037RD - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Red Anodized, Set of 4 Ship Date: Tomorrow
Price: $25.99
Gorilla Automotive 42133AL - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Silver Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Kluhsman Racing Components 8207 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 18 RH, Open End, Yellow PTFE Coated, Aluminum, Set of 20 Ship Date: Tomorrow
Price: $34.88
Kluhsman Racing Components 8203 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 12mm x 1.50, Open End, Black, Aluminum, Set of 16 Ship Date: Tomorrow
Price: $51.95
Kluhsman Racing Components 8210 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 7/16 in. x 20 RH, Open End, Black, Aluminum, Set of 20 Ship Date: Tomorrow
Price: $51.95
Gorilla Automotive 44037TI - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Titanium Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 42123BK - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Black Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Gorilla Automotive 42123AL - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Silver Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Gorilla Automotive 42133TI - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Titanium Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Kluhsman Racing Components 8201 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, Double End, 5/8 in. x 11 RH, Open End, Black, Aluminum, Set of 20 Ship Date: Tomorrow
Price: $51.95
Gorilla Automotive 44037AL - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Silver Anodized, Set of 4 Ship Date: Tomorrow
Price: $25.99
Gorilla Automotive 44137BL - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Blue Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44027BK - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Black Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Kluhsman Racing Components 8205 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 18 RH, Open End, Black, Aluminum, Set of 20 Ship Date: 10/8/2012
Price: $51.95
Gorilla Automotive 42133BL - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Blue Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Gorilla Automotive 42133RD - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Red Anodized, Set of 20 Ship Date: 10/15/2012
Price: $104.99
Gorilla Automotive 44127BK - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Black Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Kluhsman Racing Components 8208 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 18 RH, Open End, Yellow PTFE Coated, Aluminum, Set of 250 Ship Date: 10/8/2012
Price: $355.95
Kluhsman Racing Components 8211 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 11 RH, Open End, Black, Aluminum, Set of 20 Ship Date: 10/8/2012
Price: $51.95
Gorilla Automotive 42133BK - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Black Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Gorilla Automotive 42123TI - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Titaium Anodized, Set of 20 Ship Date: Tomorrow
Price: $104.99
Gorilla Automotive 42123BL - Gorilla Small Diameter Lug Nuts Lug Nuts, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Blue Anodized, Set of 20 Ship Date: 10/8/2012
Price: $104.99
Kluhsman Racing Components 8200 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 11 RH, Open End, Black, Aluminum, Set of 20 Ship Date: Tomorrow
Price: $51.95
Gorilla Automotive 44137TI - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Titanium Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Allstar Performance ALL44097-100 - Allstar Performance Lug Nuts Lug Nuts, Conical, Double Chamfer, 5/8-11 RH in., Open End, Aluminum, Black Hard Coated, Set of 100 Ship Date: 10/8/2012
Price: $179.99
Allstar Performance ALL44096-100 - Allstar Performance Lug Nuts Lug Nuts, 5/8 in.-11 RH, Double Chamfer, Aluminum, Set of 100 Ship Date: 10/8/2012
Price: $149.99
Kluhsman Racing Components 8204 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 11 RH, Open End, Black, Aluminum, Set of 20 Ship Date: 10/8/2012
Price: $47.95
Kluhsman Racing Components 8208X - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 18 RH, Open End, Yellow Painted, Aluminum, Set of 250 Ship Date: 10/8/2012
Price: $359.95
Kluhsman Racing Components 8206 - KRC Racing Lug Nuts Lug Nuts, Conical Seat, 45 Degree, 5/8 in. x 18 RH, Open End, Black, Aluminum, Set of 20 Ship Date: 10/8/2012
Price: $51.95
Gorilla Automotive 44027RD - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Red Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44027BL - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Blue Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44027AL - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Silver Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44127BL - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Blue Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44127AL - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Silver Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44127TI - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Titanium Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44037BL - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Blue Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44027TI - Gorilla Lug Nuts Lug Nuts, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Titanium Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44137RD - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Red Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44137AL - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Silver Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Gorilla Automotive 44127RD - Gorilla Lug Nuts Lug Nuts, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Red Anodized, Set of 4 Ship Date: 10/8/2012
Price: $25.99
Allstar Performance ALL44097 - Allstar Performance Lug Nuts Lug Nut, Conical Seat, 5/8 in.-11 RH, 45 Degree, Double Chamfer, Aluminum, Black, Set of 10 Ship Date: Tomorrow
Price: $19.99
OER K135 - OER Wheel Lug Nuts Lug Nut, Flange Style, 7/16 in.-20 RH Thread, Aluminum, Chrome, Buick, Chevy, Oldsmobile, Pontiac, Each Ship Date: Tomorrow
Price: $3.95
Allstar Performance ALL44096 - Allstar Performance Lug Nuts Lug Nut, Conical Seat, 5/8 in.-11 RH, 45 Degree, Double Chamfer, Aluminum, Set of 10 Ship Date: Tomorrow
Price: $17.59
Gorilla Automotive 44038BK - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Black Anodized, Each Ship Date: Tomorrow
Price: $7.99
Gorilla Automotive 44138BK - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Black Anodized, Each Ship Date: Tomorrow
Price: $7.99
Gorilla Automotive 42138TI - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Titanium Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42138AL - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Silver Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44128BK - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Black Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42138BK - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Black Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44138AL - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Silver Anodized, Each Ship Date: Tomorrow
Price: $7.99
Gorilla Automotive 42138RD - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Red Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44128TI - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Titanium Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44038BL - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Blue Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42128RD - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Red Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42128TI - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Titanium Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44138TI - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Titanium Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44138BL - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Blue Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44028BK - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Black Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44038TI - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Titanium Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42128BK - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Black Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44028TI - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Titanium Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44028BL - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Blue Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44038RD - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Red Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44128AL - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Silver Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44138RD - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.50 RH, Aluminum, Red Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42138BL - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.50 RH, Tuner, Aluminum, Blue Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44028AL - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Silver Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44128BL - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Blue Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44128RD - Gorilla Lug Nuts Lug Nut, Closed Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Red Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 44028RD - Gorilla Lug Nuts Lug Nut, Open Hex, Conical Seat, 12mm x 1.25 RH, Aluminum, Red Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42128BL - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Blue Anodized, Each Ship Date: 10/8/2012
Price: $7.99
Gorilla Automotive 42128AL - Gorilla Small Diameter Lug Nuts Lug Nut, Small Diameter, Conical Seat, 12mm x 1.25 RH, Tuner, Aluminum, Silver Anodized, Each Ship Date: 10/8/2012
Price: $51.95
Sorry but as my name on here should lead you to believe I am a Tuner Guy with my Subaru. Out of all the years at the Chassis Dyno Shop working on cars I have never seen a car with Aluminum lug Nuts. Must be the Poser Tuner guys that use stuff like that cause I have never seen this stuff on anything I have worked on. Even when I had some Honda's I paid a lotta money for a set of Keyed Lugs and they were Steel.
Funnier yet my main engine machine shops owner who spares no expense on his stuff made light weight lugs for his daughters quad style Buggy out of Titanium.
So not calling you a liar or anything but for me the only reason I would make a Lug Nut out of Aluminum would be to make a demonstration piece or at the most a show piece. I mean I am one of those people that torques lug nuts to manufacture spec and don't just wing em on with a impact gun.
This is exactly why I showed the alum lugnuts to freak some out. It worked. This is only to go str8 not turning and not on the street. There are tons of guys running 7,8,9 sec 1/4 mile times with alum lugs.
I will repost my disclaimer lol
I guess I've never been in the market for aluminum lug nuts and its funny he made them because Tuesday this week a guy had his RSX in the shop with red lug nuts. I asked him if they were powder coated and he said "no, anodized aluminum". I thought it was a little strange, I've seen them before in a through hole plain finish at the drag strip but found out it wasn't. I did a google search; Corvette, Mitsu, and Honda forums is what popped up the most. Like I said, most were because of color match or just plain old show.. can't make this stuff up.
Its a Powermatic/logan. circa 1975?
Have used many Lathes and that one was unfamiliar to me. I personally own a non CNC MORI SEIKI and use an older Servo Shift LEBLOND from the US NAVY at my brothers shop.
I still can't see living life working on vehicles without having these tools.
