MarkVIIIS
I'm looking to either do gray or silver I think some shade of gray
The work you did on the shifter look's excellent!! It makes me think twice about what I want to do with mine. I'm gonna have to keep this thread in mind. You did very good work! My compliments to you...for a job well done!!!To take the shifter apart, you slide the vertical sleeve down and there in a screw or two that come out and the shifter slides right off.
the knob i am using is an aftermarket mustang UPR one. I did remove the spring inside it cause it was to stiff, and I also had to put it on my lathe and turn the recess a little deeper to allow more travel for the center button.
The OD button i used if from a 06 explorer shift handle. I had one laying around since i put a Flex shift in the wifes explorer.
The boot is an ebay speical for a mustang as well. I love the look and feel of the new setup.
I ended up doing 3 coats of primer wet sanded then 3 coats of paint wet sanded then 2 coats of clear might do more it looks good but I don't know if the 1000 grit was too much or if I was putting too much pressure on it but if u look at the trim from the right angle u can kind of see the scuffs under the clear but not too much I think I might use 1500 or 2000 for the rest
Can anyone tell me the bulb size for the gauges and how many there r I want to put some LEDs in it
My pass door interior panel is starting to peal up near the window was wondering wut would be the best thing to use to glue it back down
This should help you with your door panels.
http://www.lincolnvscadillac.com/showpost.php?p=761418&postcount=83
