Air Bag ground?
Hemihed426
Inman
Hey guys, my 94 Gen 1 just lit up the airbag light and I've read on here that it is usually a ground up in the front bumper area. I have looked high and low and can't find it. Can anybody point me in the right direction?
like safety air bag light? did your clock spring die?
hows your cruise control or horn?
Like mentioned above, clock spring might be bad however if your clock spring is bad you won't just get an "air bag" light. You'll get an annoying beep every time you start your car. It beeps in sets of 3 beeps for 30 seconds to let you know your airbag is kaput!
i thought that was only if the light bulb burned out?
A bad bulb will cause the beeping, not a bad cs. In a g2 it will throw a 32 (3 blinks- pause-2 blinks) code for a bad cs w/o any beeping.
No beeping, just lit the airbag light on the piano. Also I have developed a stall after I have started the engine and ran it for awhile then cut it off then restart it and it will stumble then take off and not do it again. Related? Cruise and horn are working fine.
The 32 airbag light will also light if the seat sensor is corroded. The one that senses if there is someone sitting in the seat. It's under the seat. I had hoped that was my problem but my horn and cruise are gone too so it's my clock spring.
