Outlaw94
My 94 is only blowing air out of the defrost and I tried the original climate unit with the same results.Is the blend door actuator bad if so how to replace it?.
What is the black box next to the blower motor for?. There's nothing plugged into it and that's probably what the two plugs down by the kick panel are for.On the black connector someone cut a green wire and spliced it into another green wire just above it.Why would some one disconnect that box and try to rewire it?. Thanks
