What transmission cooler is everyone running? Any recommendations?
Tru-Cool 40,000#gvw stacked plate cooler.
Looks like this thing could cool a big rig lol. Did you have to buy anything else to get it installed?
Not that I recall. I'm almost certain it came with everything needed to hook it up. Mine is behind the front bumper in front of the radiator.
And yes, it does its job. I was reading under 170 degrees via scan gauge after 20 minutes of spirited driving in the middle of summer. I borrowed my buddy's gauge just to see how efficient it was and that's what I came up with. Good enough for me!![]()
I know it works well but I am a bit concerned of adding weight to the front end. Any idea how much it weighs?
Are there any issues with it blocking too much flow into the radiator? Also what did you mount it to?
Actually, I'm using a B&M 70297 cooler with an integrated fan, bypassing the radiator.
Doug, do you remember what size fittings these are going into the trans? Nice install btw.
Thanks, that's a lot nicer than the steel lines.
I just had a set of lines made up in stainless for a car that's currently on my lift.
That one is a little rusty, looks like it will need ps lines in the future. No where near as clean as your car.
Here is my write up with pics and part #'s. You can mount it lower too, peeps do it that way also.
http://www.lincolnvscadillac.com/showthread.php?t=73827
sweet, thanks man.
