jarrett88
My check engine light came on so I went and got it code-read and it came up P0171 System Too Lean (Bank 1 in engine) What does this mean and what or how do I fix this?
Bad/marginal coils (replace coils and plugs)
Intake air leak (maybe PCV plumbing)
Bad MAF
Bad fuel injector(s)
Clogged fuel filter
Bad fuel pump
Bad 02 sensor
Slipped timing chain
Your knowledge is rather impressive...
broken-dear god i'd hope so
Why do you say that
a broken timing chain is not the best for the performance of your LS :shifty:
usually leads to catastrophic failure of the engine...
That you should hear
hah, it was more of the context. Anywho the only sound I really hear is an air sound mainly when the car is on and in park
I would make sure your connection to the throttle body is tight, and all accessories leading from the intake are tight. If they are good, move on to replacing the throttle body gasket. If it's just bank one, it might be the intake manifold gasket for that bank sucking by air.Your exactly right Joe
Okay, so I took it in to the shop today, and oddly enough they were not able to identify where the leak was coming from, so how can i go about checking all these things out that you said I should check? such as throttle body gasket, and intake manifold gasket
Don't forget the PCV plumbing as well.
One way is to spray starter fluid around where you think it could be. When you hit the right spot, the engine will react. (If this goes badly wrong, please don't sue me.)
Hahahaha, when I read the starter fluid I was like "oh my, get out the marshmallows" (had it happen to me with carb cleaner). Safe way is to use
propane and spray around until you see you sprayed an area that changed engine idle.
Propane is a bit safer, but "safe" isn't really the right word either.
