Rollin, you're correct. They are high and low beam projectors. I lowered the car 2" over 20" wheels w/ Bilstein H6 Jaguar S-Type R front and rear shocks on Eibach sport springs. Lincoln parts couldn't get nowhere close to the performance this setup provides. The grille is screwed up, I know. I messed it up in an attempt to matte black it. My car will eventually be matte black in the near future. So no, the grille will go. It will actually be molded into the hood. I have never been a fan of part lines, especially where the parts should be one piece. As far as the different color HIDs, one of the ballasts is not operating efficiently, cause one bulb to burn lower than the other. They have been in operation for four years already. It is time replace them. As far as the engine goes, it has been replaced with a crated OEM engine that had 42,000 miles and a head rebuild. The tranny was also rebuilt with modified gearing. I currently use a SCT Livewire 9600 to make mods as necessary. Btw, if you don't have a SCT device, yo should make the investment. Thank you all for your input. Also, I do all mods myself. I have been out of the car game for a while but after seeing all of the LS's out there with mini-mods, I have decided that it is time for my return to the streets to join you folks.
Later
