fishbone1
I have a 2000 LS Sport. It appears as if it is overheating but I am 99.9% certain it is not. I hear the fan increase in speed...the temp gauge increases steadily and very quickly till the care goes into reduced power mode...I pull over....I turn the car off.....I immediately turn the car back on....FM!! the car is running pefectly and the temp gauge is sitting just below the halfway mark. This has happened maybe 10 times in the last month. Could a bad coolant temp sensor  cause this problem? I need help from an LS guru. Thanks
