tbirdnlincoln
I know that some of this has probably been presented in pieces in various forums before,
but I need some assistance in installing my XM in my 02 LS with the Alpine in dash CD changer.
I plan on installing a Pro Fit LC-53-00 bracket, and P.I.E. FRDN-AUX direct input adapter. I have directions from Pro Fit (http://www.pro-fit-intl.com/Adobe/LC-53-00.pdf) lincolns online (http://www.lincolnsonline.com/article82.html) , and lloc on how to get to the radio, and was wondering if there are any additional suggestions to help me accomplish this. I am also planning on installing a power socket somewhere behind the dash under the console, tapped into the radio power (retained power accessory) wire & ground. I don’t really know how to get the console pieces off or where exactly to get space and access for the socket and wiring. I am also uncertain of where to run the wires from the mounted XM to get to the socket, the PIE adapter and the antenna. Finally, I am looking for suggestions on how to run the antenna wire. It looks like I will be mounting it in the center of the roof, and run the cable under the weather stripping along the windshield. Then there is the matter of how to get it inside. On my Aurora, I ran it through the door crack, and taped it to the door jam. On the LS, there is a rubber plug in the jam. Can I run the antenna cable through this hole and still get the plug back in? Thanks!
