WTB: Cooling Fan Pump.
steeda
LVC
I am in need of a Hydraulic Fan Pump for my 01 LS 3.9. Needs to have the pulley on it also. If you have one you want to sell send me a message and we can work out a deal. Thanks!
I wouldn't put a used one in there. That is unless you like doing this multiple times.........
I am a mechanic so taking it off and putting it on isn't that big of a deal. The one on my LS is starting to fail and I am looking for a used on to throw on there while I source the needed parts to rebuild my current one.
Chances are you just need the solenoid.
Have you tried a wrecking , er, recycling yard?
Solenoid is good, bearings are letting loose and the pulley and shaft are starting to move in and out at higher rpm. I have only checked with lkq through my work and even with our discount it was still salty. Plan on hitting the local pick-a-part this weekend if I can't source one before then.
Pick n pull is your best bet. Don't think I have one left in my pile, although I have several fan motors.
Good luck on the rebuild kit. Let me know if you find a source! I'd like to rebuild my steering pump instead of replacing it.
