won't start
parmaredmen16
parma
My mark wouldn't start today after sitting a while, starter wouldn't pull in just clicking.I put it on charge for about an hour, opened the door, no light, turned the key nothing,no idiot lights no clicking, nothing at all. HELP
corroded terminals.
dead battery.
dead starter.
etc.
start by cleaning the battery terminals.
Disconnect the battery and reconnect it while looking for corrosion on the terminals.
Worth a shot
Grab a multimeter and test the voltage of the battery, it should be around 12v.
If it's way less, the battery is toast. If the battery is fine, check the terminals attached to the battery as suggested, clean any corrosion you see. If it's not that you can start the fun troubleshooting
