Windows Roll down after Shutting Car off...HELP
LS2001EB
Fresno
After I shut the car off my seat goes back, the wheel tilts back up and all that is fine and I like all that. What I don't like and don't understand why its happening is all 4 windows will roll down about 2 inches and stay there. I've searched everywhere and even read the owners manual and can't find anything. Please any help would be appreciated. Thanks to everyone for the help.
theres a feature on the car that if you press either the lock or unlock like three times, not sure which one it may be both, it will roll the windows down and im pretty sure that if you hold it down they roll all the way down not just a little bit, the sun roof will also open
the battery on my keyfob is fine...I tried hitting the lock and unlock button 3 times and still nothing. It's just weird because it wasn't doing this before now it is.
Soon as I turn the car off all 4 windows roll down 2 inches. Thanks guys.
It's the car's battery that you should check.
The windows all roll down if you press and hold the remote unlock button for a few seconds. They will also roll down if you put the key in the driver's door lock and turn it to unlock for a few seconds. They will roll up if you turn the key to the lock position and hold it there for a few seconds (you have to keep it in the lock position until they have all completely closed).
You might want to put the key in the driver's door lock and cycle it between lock and unlock a few times to clean the switch contacts.
