Window switch covers
TheBigRedOne
Montgomery, AL
Both of my drivers side window switch covers came off and I noticed that one of them is larger than the other. Does anyone know which one goes where?
Trial and error is what I did
Figure out what works/fits the best and go with it.
x2. Iirc they have a certain contour to each of them. Keep switching between the 2 and turn them around if need be. A few carefully placed drops of sg and she'll be all better.
While we're on the subject, how do you remove the power window/door lock switch panel from the door panel? The mounting brackets on the underside of mine have apparently broken and my PW switches are now sunk down into the door panel. I've tried prying it out with a flathead screwdriver, but it won't budge and I didn't want to break it any further. Does the door panel have to come off to get to it?
Yes, sir. It's not that bad of a job.
I figured as much:( I've had the door panel off before when I replaced the outer door handle. I need to take it off anyway and fix the arm rest that's trying to come loose. I can just add that to the list of little nitpicky things I will be doing to the car once I get my Exploder back on the road:)
