windage tray?
This is a good ?. Do our cars have one stock? Or will our main caps and pan not allow it?
I wouldn't say it is too good to be true, but 15hp i dunno.... but the product does look like a high quality peice from a trusted website.... you tell us when you get it installed
15 hp yes at the flywheel. If it is doable. From mail order and not custom made.
i know are cars do not have one stock. i took my engine out 2 years ago to changed the oil pan, and i did not see anything like this there . had i known this existed i would have slaped one in at that time but trying to slip one in with the moter still in the car would be a B!tch.
I do not believe the Mark VIII oil pans will work with this. I seen one used several years ago with a custom oil pan.
I am pretty sure it won't work b/c of the scrapers built into the bottom of the pan. I thought I read this a while back when a buddy and I built a Mark motor for a fox body project. You would have to grind them down. I thought Ford Racing makes a tray too, only it is a half tray in the sump area only.
