T bird rims will, not sure on mark rims, i think some do, not all though. I have seem many marks with mustang rims but mustangs use offset in the high 20's I think. I have also seen them with ls rims though. Stock ls wheel offset if +60mm, you can go down to about +38, but you might might be cutting it close with 38. What rims were you looking into?
The '89-'97 T-Birds also have the same bolt pattern as the LS. They have a significantly different offset, though, and I don't know if their wheels will clear the LS's calipers.
i had my chrome wheels from my mark on my 1st gen for a summer, they fit fine, but the offset was pretty extreme, the wheels almost stuck out too far!
so the newest generation T-bird wheels should be the exact same size and off set, the older ones(these are the ones assume that you are talking about since the T-bird/couger/markVIII are all about the same vehicle, well not the mark its much better.lol) have the right bolt pattern but a way different offset
