why do i get the weird problems?? HELP!!!! bad miss
richduty455
South Jersey
First off let me start off by saying "Hello all!!" its been a while, damn work blocked this site so I can't get on here alot :( ANYWAYS......my 94 is acting CRAZY and I have no idea whats wrong with it......car seems like its running with a miss.....at idle sometimes it miss a little other times it will run really rough....other times it will idle smooth.....as for driving....sometimes its PERFECT will tons of power then other its low on power and feels like its running with a bad miss...any ideas? Here's what I've already replaced....coil packs, wires, plugs, MAF sensor, air filter. Anyone have this problem? Worst part is sometimes it clears up then comes back. Help me plleeease!!! Other than that the car runs fine, no CE lights, fuel milage is right where it should be too......
Swapped out the IAC lately? TPS could also be playing a part with it acting like that but usually it has an effect on the idle. Plugs gapped at .054? While it's running, pull one wire off the coil at a time and check for good spark. Not sure what kind of wires you used but one of them could be bad, even if it's new and or a plug could also be fowled or fowling out even though it's new too. When it's acting up during idle, I would check the spark and that should either point you to the one that's bad or going bad, if it's even got anything to do with a plug or wire. Other than that, I don't know what else it could be. I would mention that one of your injectors might be trying to go bad on you but me and injectors don't speak anymore lol.
