131F sounded nuts to me, but apparently is perfectly normal for lower engine loads and not much air moving through. $15 sensor did zip.
I played with the scanner some more, never figured out the trick to running the KOEO or KOER tests, but finally did notice that the tests the car does automatically, all completed except evaporative emissions.
I pulled the MAF and air tube to the throttle off, and started looking hard with a flashlight for anything suspicious. Vacuum fitting to the intake looked a little loose so I pulled it all the way off, and seated it back down tight. Reached over for the 90 degree elbow fitting that goes to the PVC, and it was rotten mush with a pencil sized hole.
Did some online searches, and PVC 90 degree and stalling gave several hits, so its common failure. Found some stories of people paying the dealer $1k to sort out a stalling issue and turns out to be this $22 part. Ford was out of stock on the whole freaking west coast, so still waiting on new part to show up, but a GMC PVC tube from Kragen looked like it would fit, and it did. No more codes.
On the road again ....
