Where is the fuel filter located???
Uncle Vinnie
Canada
I'm looking to change the Fuel filter of a 2003 Lincoln LS V8, can anyone tell me where it's located, and is it easy to do it yourself..
Thank you
A search will tell you it's behind the driver's side inner fender liner.
Thanks a lot I did find it....however I can't read.
All the search I did, said the same thing "drivers side front wheel"
Well...don't I go and take apart the PASSENGER side front wheel and of course there's nothing there.:eek:
take the driver side front wheel off and then the back wheel liner. its right there. 15 min job well worth it..
Yea, and a hot tip. Just push in the green catch rings with a flat blade screw driver to release the filter from the tube connector. It will pop right out.
all done and finished, faster than I though.
Seems to be running fine.
Thanks for all your help
