Wheels
BLACK SNAKE
bradenton
I am thinking about sending my wheels out to be widended, from 7.5" to 10" will they fit my 97' mark viii. Then they ask do I want then wid. from the inside? or the front .Will I need spacers? I sure this questioned but I am little slow. the place I am sending them to is weldcraft in mi. .has anybody used them thanks for an answer.
My 17" x 9" wide wheels with the factory offset just miss the front spindles. You can not use wheel weights on the inside, they hit. Used stick on's.
You will want an offset of +40MM - +45MM...No more and no less. So if you want a lip then ask for it so long as it ends up with the above specs. I would lean toward the +45MM myself.
Brad
Go with weld craft wheels. I just got my broken rim back from repair and they did a great job.
