stallone 81
got spacers for the rear but not the front what size studs do i need ? im ordering them from http://www.motorsport-tech.com and i noticed that i cant order 25mm ?
They will make them for you special for 25mm if you ask them. Give them a call and ask to talk to Junior he should be able to help you out.
You technically are just ordering a 5x108 to 5x108 adapter. 25mm. Center bore is 63.9. The pressed in studs should be around 14mm in length
Did you test fit the ones you got yet?? I wanna see how they look![]()
