wheel spacer
They will make them for you special for 25mm if you ask them. Give them a call and ask to talk to Junior he should be able to help you out.
You technically are just ordering a 5x108 to 5x108 adapter. 25mm. Center bore is 63.9. The pressed in studs should be around 14mm in length
alright man thanx ill give them a call today
Did you test fit the ones you got yet?? I wanna see how they look :)
