godspunk32
Hello-
I'm new to the forum, and I'm sure this has been covered before, but I have questions about the wheel offset on the 2000 LS with 16" rims.
I own a Mercury Sable, which has a 5x108mm bolt pattern, and +42mm wheel offset. I've seen conflicting reports that the offset of the LS is either +40 or +60 mm. Tirerack even shows 16" rims for the LS as having a +40mm offset. So which is it? I'm trying to buy a set of 16" rims from a 2000 LS, and I'm not sure if the offset is correct.
Thanks,
JR
Thanks,
JR
