Wheel bearing He11, 1/2 over
Kevin
Ingersoll Ontario
Just completed the front right wheel bearing on my 2000 LS.
Was alot easier than the left side, we used an air chisel for that. This time I got smart and used a propane torch to heat up the aluminum piece that the bearing sits in, to expand it away from the metal bearing.
After beating on it a bit, to turn it in it's hole, I managed to get the slightest bit of gap in there, which I managed to get a small flat screwdriver into. A series of larger and larger screwdrivers at the bolt holes to pry it out of the hole, and it eventually popped out.
Total job time, about 2 hours, including time to curse and swear at it, drink a beer, give up, go to bed, get up and go again.
Recommend letting it sit overnight with WD40 or other penetrating agent.
It's a bugger, but it's doable.
This is something that I would love to have a tech article on. I need to do that soon here, and if someone would write one, us not-so-smart kids would love it.
Eh, I'm one of those not so smart kids myself, but got tired of worrying about how the job would go - and just did it.
Simple tech article follows:
Take off wheel and brake caliper and pads, and bracket for caliper, and rotor - and remove bolts holding in wheel bearing.
SOAK with a penetrating oil.
Let sit (overnight?), drink a beer, play with wife/gf, go for a walk, watch TV, surf internet, sleep, whatever.
Return to car, heat aluminium support with a torch.
Pound the crap out of the hub and/or flange around the bearing.
Repeat using the torch for as long as necessary to loosen the bearing.
Swear at it a bit, it helps.
Get enough play to insert chisel/flat screwdriver. Put as many of those tools in the ever widening gap as you can, and it falls out.
Put in new one, and reassemble.
It's really not a hard job, just dealing with the corroded metal of the bearing is frustrating.
My car drives alot straighter now, needing little correction going down the road, and my ABS/Advance Trac lights have now gone out on the gauge panel.
Well that sounds easy enuf, might give it a try. My rear bearing also needs replacing, would enyone have simple instructions on that one?
