Whats the lifespan of the stock 4.6
Lincoln Town Car
  1. inurok
    inurok LVC Member
    29
    Apr 5, 2005
    Texas
    I sold my 2006 LS and bought a 2007 towncar executive L. Super high miles on it 455K is there anything I should be concerned about ? Runs and drives fine but engine sound makes me think I have a exhaust manifold leak.thx
    Paid $1800 for it sigh...
  2. slowmkviii
    slowmkviii Dedicated LVC Member
    5,520
    366
    Sep 28, 2007
    Elk River, MN
    Timing chain tensioners
    Inspect main bearings
    The coolant hose in the valley
    If the car is nice just buy a spare low mile motor.
  3. inurok
    inurok LVC Member
    29
    Apr 5, 2005
    Texas
    well its at 458500 now runs okay except for charge light still coming on off. I changed the harness seems like pulling the harness off the connector and back on fixes alleviates it for a little bit. How can I tell if its the original engine? I see it has the fins on the valve covers and I thought 2007 up were smooth? Is it common to get over 500 thousand miles on the original engine. No cel lights or smoking but should I bee concerned?
  4. jnb0111
    jnb0111 New LVC Member
    8
    Jun 30, 2011
    Columbus
    Most people don’t drive enough to get to that mileage, but yeah they will last if you put the miles on.
  5. Svets96
    Svets96 Dedicated LVC Member
    529
    63
    Jul 18, 2005
    North East Ohio
    I believe there is a barcode on the driver side cam cover. Cross check that with the vin # with the dealer or so. I've seen these engines go over 1 million miles. Just use preventative maintenance, oil changes, fluid changes, and filters. Some do burn oil, but that is from not changing it, along with the valve stem seals needing changed. That's common on higher mileage.
Share This Page
