What brake fluid does LS use?
From page 276 of the 2003 owner's manual:
Brake fluid
Motorcraft High Performance DOT 3 Motor Vehicle Brake Fluid*
* Use only brake fluids certified to meet Ford specifications. Refer to Lubricant Specifications in this chapter. DOT 3 fluid is recommended. However, if DOT 3 is not available, DOT 4 fluid can be used.
or you can upgrade to full synthetic that is compatible with DOT3/4 systems.
