What a night! Please have mercy lvc board
fudge12
Brooklyn
I left work to drop my gf home in the hard pouring rain (visibility is literally nothing) and after I dropped her home, I stopped at a stop sign while i looked for my phone. Immediately after I look up at the windshield I see thick heavy steam coming from under the hood. Immediately I pulled over and noticed that there's a fine coolant line running to where the thermostat housing is (also the coolant bleeder valve is there.) The plastic nipple that goes into the rubber hose broke clean out. I managed to attach the hose with what ever remaining nipple was there and refill with coolant.
Soaking wet, I got back into the car, took off and there was no steam anymore. Leak fixed right? :D Right but now another issue. Overheating :mad:
Again I had to pull over with rain falling much harder than before. I got out my flat screw driver and began to play with the bleeder valve with what ever visible ambient light available. I began to turn but noticed that I was getting no where. With my already water damaged iPhone, I shined the light on it and I see that the valve is broken. Just great :Bang
With only one option to make the 10 mile trip back home, I had to blast the heat (of course none of which came out), wipe the windshield with paper to see what I was driving through, and turn the car off at every stop to avoid getting into the 4/4 zone which I ended up driving into anyway. As I neared home, the car wouldn't overheat too quickly but still stayed within the 3/4th zone and crept up ever so slightly.
Tomorrow morning I have to take a closer look for anymore leaks. Is there any other way I can bleed the system without that valve?
bleed the system with out the bleeder valve? probably not, if this car is not bled exactly as it is supposed to be, you will not get all of the air out, with out getting all of the air out, you will continue to over heat...
you will have to replace any damaged parts (while your at it,you should replace all plastic parts as they have the same life span, and the rest will be soon to break as well, if they don't break while you take it apart to replace the parts that are broken...)
