warlockpain
it may be shot,i dunno.
the car sat for a few months, went to get it back out again, dead battery.
battery was under free replacement warranty so got a new one.
started the car up,started checking fluids,noticed trans fluid wasn't touching the stick,hmm odd, nothing under the car leaking.
went back to the auto parts store, got 1 qt of lucas trans additive and 2 quarts mercon V, put those in the car,shifted through the gears, level ok.
now time for a drive, took off fine,shifted through all gears perfectly, drove 2 miles,turned in to head back, no forward gears!!! reverse is fine,so backed it home,checked fluid again,2 quarts low,still no leak to be found. added the 2 quarts and still no forward gears no matter what.
i've never heard of all the forward gears going out at once like this with no warning. is there a solenoid problem or something simple?
or is the trans just straight TOASTED???
94 m8 btw.
need help please, if it's not a simple fix then it will be sold,traded,or parted out. i'm going back to my 5 speed mustangs!
94 m8 btw.
