roncoinc
With the air on high/recirculate and the probe on my fluke down the vent the air temp was 64* at ambient 80*
so i used a hose and gauge from a DIY fill kit.
put it on the low side fitting and ran the car 15 min or so and went and looked at the gauge..
right at min press,,28 lbs or so..
thinking,ok low on coolant..
then i see the needle on the gauge wiggle,up and down a couple pounds,,then the needle goes up,and up,and up,,reaches 60 lbs and the comp shuts off,press drops and it cycles again..
then it hold at low press awhile,,then cycles again..
last year about this time i had 54* air and i could live with that.
so it lost 10* in a year.
i googled untill my eyes got googley,,talked to an HVAC guy,mechanic ,several people and no good answers about THAT much fluctuation on pressure.
tomorrow will borrow a manifold set and get better readings..
WTH could make the low side press fluctuate 30 lb's ??
