Hello  When I first got the LS a few months ago the heat didn't work.  At that time, I did the HVAC self test and received a code.  I can't remember and didn't pay it much mind because I wasn't worried about the heat.  Fast forward, I turned the A/C on and it works well...until it overheats.  I found this thread (http://www.lincolnvscadillac.com/forum/showthread.php?41319-01-LS-Overheating-(only-when-A-C-is-on-)) and took the cap off and ran it with the heat on.  The heat blew hot (when it didn't work before) and I let it run for about 30 minutes.  The fluid level stayed the same.  I tried the AC to see what it would do with the cap off and it worked with no problem...never overheated.  When I put the cap back on the heat didn't work well and the AC overheated.  I googled and searched a lot of links on here and wasn't able to find the exact thing duplicated.
I read that the fan should kick in to a higher mode when the AC is on, but I can't SEE the fan. I have looked and I can't find it. I did the self test with the defrost and off again and all lights came on (which from I read on here indicated no error?).
Is there a fuse or relay that may be causing this? All fluid levels are good to go.
Any help or advice is appreciated. Thanks!
  When I first got the LS a few months ago the heat didn't work.  At that time, I did the HVAC self test and received a code.  I can't remember and didn't pay it much mind because I wasn't worried about the heat.  Fast forward, I turned the A/C on and it works well...until it overheats.  I found this thread (http://www.lincolnvscadillac.com/forum/showthread.php?41319-01-LS-Overheating-(only-when-A-C-is-on-)) and took the cap off and ran it with the heat on.  The heat blew hot (when it didn't work before) and I let it run for about 30 minutes.  The fluid level stayed the same.  I tried the AC to see what it would do with the cap off and it worked with no problem...never overheated.  When I put the cap back on the heat didn't work well and the AC overheated.  I googled and searched a lot of links on here and wasn't able to find the exact thing duplicated.  I read that the fan should kick in to a higher mode when the AC is on, but I can't SEE the fan. I have looked and I can't find it. I did the self test with the defrost and off again and all lights came on (which from I read on here indicated no error?).
