mharrison
Well, over the weekend I replaced the PCV valve elbow hose that is buried underneath the intake. It was a real PITA, but then again it wasn't that hard. I guess the big PITA part is that you shouldn't have to disassemble the top of your engine to replace a PCV valve hose!
The hose was completely collapsed and then got a hole in it. I had the both banks running lean codes (0173 & 0174 I think?) After I replaced this, I cleared the codes with my reader and have been code free. It had gotten to the point that it was dying while idling.
I also replaced the passenger front door regulator. As usual the 50 cent piece of plastic broke forcing me to buy a $150 regulator assembly.
This is by far the easiest time I've ever had replacing a regulator assembly in any car. I love the way the door is built with the big silver plate that is removable. This was a piece of cake. I did however put everything back together and then see the sound proofing/vapor barrier laying on my trunk when I went to put up my tools!
Taking it all apart and putting that back on wasn't too bad though!
I did this from 10am to 2pm in my carport. Fortunately, even though it has been around 30 degrees at night, it was 75 degrees at 1pm the day I did this! (I looked at the 10 day forecast last weekend and decided to wait for this nice day!)
