Water spraying from muffler
Stevemata
Northern California
I recently had some overheating problems, I replaced my thermostat and it's cracked housing.
I noticed since my overheat incident that my muffler is spraying water when I first start the car. After I shutoff the car I hear a gurgling sound.
I followed the air bleed instructions, coolant level is staying level after a thousand miles from the change.
Any idea?
It is normal to have some water come out of the exhaust at first due to condensation, there is even a hole in the bottom of the muffler for the water to drain.
I suggest that you have a hydrocarbon sniff test done on the cooling system and pray that it is negative.
Whats the gurgling sounds, I have that too and was wondering if its ok?
after i shut off my car, i hear it too. open the hood and look at the degas bottle. it's likely fluid draining back into it. i don't know if it's normal or not, but mine does it.
