water pump question,QUICK!!!
Moes8
Berks County Pa
quick question for anyone who has done a water pump on the mark 8's.
i dont have a garage,it is gonna snow here in a few hours,and i just realized my water pump is leaking a decent amount,
i know i can pull it off and replace it fairly quick,how much coolant will i lose?i dont have much time,so if it is gonna require me having to do a full cooling refill and air burp and all that jazz,i am going to leave this job for later this week or next,after the weather clears,
thanks guys. you rock
um...no
when i did mine my system was full and i lost nothing.
They switched to a better, more effiecient water pump design in the 99 Cobra. You may gain up to 5hp with this mod as well although it won't be noticeable.
95LSC32V said:
Get a 99 Cobra water pump from the dealership...
will this be a direct swap,bolt right in?
i dont want any hassle for maybe 5hp,
also,does it have to be stealership unit,?
thanks guys.
I haven't done it before but it should be a direct swap. also you probably want to get a Motorcraft one which doesnt have to be from the dealership but atleast dont get some aftermarket one
