I've searched though the forum and read many entries, but I haven't seen what I am looking for...
I have water inside the front passenger door, sloshing around, after a car wash or rain (not inside the car, but inside the door itself). I originally thought that it was the window not going up tight for months, and had the window regulator recently replaced... so the window is up tight now without any air leaks. Still getting water inside that door.
I don't see any water spots around the A-Pillar (i.e. from the common sunroof drain issue)... so I haven't looked under the headliner yet.
(There must be a drain plugged in that door, or a lack of a drain, causing the water to build up in there. It does eventually go away. I have read that some '02 LS's or Gen1's didn't get a drain hole drilled... so that is another issue to address after finding the source of how the water is getting in there originally).
Is this a seal issue around the window glass at the bottom?
Any ideas of what is causing this?
