Water in trunk
ATrom
Appleton, WI
I was going to do some work on my 2000 LS went to disconnect the negative cable and noticed there was water sitting below the spare tire. The carpet on the left side (right behind driver side taillight) was all wet so I took it off and saw this hose just draining into the trunk space.
Where is this hose actually suppose to drain at?
Never seen that, but I would imagine it's the rear sunroof drain? I actually find wet carpet exactly as you described.
That doesn't look like the factory hose, but anyway this is where it is supposed to go.
