Water getting in .
Xhuco
Cali
2005 lincoln ls sport. When it rains it leaks Water in on headliner inside drivers side windows. And I get mold. Also the pocket on passenger door fills up with water. Amy suggestions.
The moon roof has 4 drain tubes. The rear 2 run under the headliner and through the c pillars and trunk. The front ones run behind the a pillars. They sometimes shrink with age or clog.
I had the same issue but my trunk was filling with water as it was the rear ones...
I didn't want to bother installing a new tube, so I adjusted the moon roof (4 bolts behind long plastic pull out sight shield that pulls out from the front side of the moon roof revealing 2 screws on each side.) loosen all 4 bolts, press the moon roof up as far as it will go and tighten the bolts while maintaining pressure.
Yes a common problem but easy to solve. The Moonroof has a drain pan with drains at the 4 corners. Over time the rubber drain hoses shrink a bit and then pull off the steel nipple. I stretched mine back into place and installed a hose clamp and never had a leak again. Others have had to add a bit of hose to bridge the gap.
Usually removing the visors allows enough room to bend down the headliner a bit to see the problem.
Adeel B. you need to start your own thread. This is a different subject.
Thank you. Much appreciated
